So yeah. Put 17's on and thought that maybe it was just me trippin but i clocked it and im much slower than stock 14 stealies. I'm a Mech Engr student and well into physics but i didnt even think about it. Feels like i lost a good 10hp and on a stock engine with i/h/e mods, thats ALOT. So yeah thats about it. anyone else have similar experiences?
17" wheels are SLOW!
rotational mass and circumference play a huge part in it.
compare your stock size to your current size here also
http://www.1010tires.com/TireSizeCal...?action=submitpost count does not reflect intelligence or experience
You also realize that the larger the circumference of the tire, the more ground you cover per revolution, which translates into a higher actual speed than what your speedometer shows, right?Originally posted by brooklynkid1986 View PostSo yeah. Put 17's on and thought that maybe it was just me trippin but i clocked it and im much slower than stock 14 stealies. I'm a Mech Engr student and well into physics but i didnt even think about it. Feels like i lost a good 10hp and on a stock engine with i/h/e mods, thats ALOT. So yeah thats about it. anyone else have similar experiences?
And that also means slower acceleration.Originally posted by mj213 View PostYou also realize that the larger the circumference of the tire, the more ground you cover per revolution, which translates into a higher actual speed than what your speedometer shows, right?Gary A.K.A. Carter
[sig killed by photobucket]
The overall diameter of the wheel/tire should be the same... there's just more wheel and less tire. Putting 17" wheels on your car doesn't donk it.Originally posted by mj213 View PostYou also realize that the larger the circumference of the tire, the more ground you cover per revolution, which translates into a higher actual speed than what your speedometer shows, right?
I put 17" wheels on my Fit. My MPG went from 38 to about 35.
I think it is a throwback to the old days, and the fact that wheels/tires are a spec item in NASCAR.Originally posted by jhoff_cb7 View Postis this why nascar still uses 15" rims??
He could have put tires on that are in fact bigger than the stock overall diameter.Originally posted by deevergote. View PostThe overall diameter of the wheel/tire should be the same... there's just more wheel and less tire. Putting 17" wheels on your car doesn't donk it.
I put 17" wheels on my Fit. My MPG went from 38 to about 35.Gary A.K.A. Carter
He could have... but without actually saying so, this isn't a valid suggestion. Most people buy their wheels and tires from a place that just gives them the proper size for their car.Originally posted by The G-Man View PostI think it is a throwback to the old days, and the fact that wheels/tires are a spec item in NASCAR.
The overall circumferance has been kept the same to deal with an increase/decrease in speedo readings.
It goes to Moment of Inertia. Basically this means that a circular object with more of is mass concentrated further from the center (our hubs or driveshaft) requires more energy to accelerate to the same speed. While i know this back and forth on paper, to see it in real life situation is shocking i guess. Imma take some measurements and find out what the actual difference is. I can feel it for sure but dunno if im being overly sensitive.
the wheels should weigh less. i cant remember what they said but they should be lighter (atleast the tire/wheel together)
If the circumference is the same and the wheels are lighter you really should get better acceleration. Yes wider tires have more resistance but you should have more grip at take off as well which should more than make up for it.
Are you positive they really ARE lighter than your stock wheels though?
