I'm picking up the wagon today they say I got a bad cylinder. I believe they said cylinder 3 I'll find out for sure once I get it. They said no compression at all in that cylinder. Is this a easy fix or do I need another motor? The say I'm better off getting another motor. What do you think, any idea's???
Bad cylinder no copression at all....
they are prolly right. you should pick up another motor so you dont have to go through paying out the ass to fix the old block.My cb7
h22a
5-spd lsd
Lord, grant me the serenity
to accept the things I cannot change,
the courage to change the things I can,
and the wisdom to hide the bodies
of those people I had to kill because they pissed me off.
perform a leakdown test to find the part causing the lack of compression.
as above, could be something small. better to check then to just toss the engine.No, I don't own a CB7, but I do own a F22A6 and a B16A trans. All going in a 90 integra sedanOriginally posted by Soichiro Honda, Honda Motor Company Ltd. FounderAction without philosophy is a lethal weapon; philosophy without action is worthless.
x2 i didnt even think about that, but it could be something small.Originally posted by randomcustoms View Postthere pretty much right your either gonna need a new head or block depending on why theres no compression,could be pricey or it could just be one or two bent valves! only way to find out is to take the head off and see whats wrong!
My cb7
h22a
5-spd lsd
I'm at the shop no where I did my swap in my LX to get that leakdown test down he is thinking the same thing. I'm praying its something simple not thrilled about buying another motor right now. If I have thinking bout another H22 that will give me a auto and 5 speed H, but we will see.Originally posted by 99EJ6T View Postperform a leakdown test to find the part causing the lack of compression.
thats what i did when i burt a valve in my cb it fixed the prob so good luck mankiss my grill
Members Ride
Originally posted by Smoken_ducky7 View Postthats what i did when i burt a valve in my cb it fixed the prob so good luck manok thanks sounds good. will a F23a1 head fit?Originally posted by madwagon View Postreplacing the head (with a good, used unit) will almost surely be cheaper than rebuilding the one you've got. (Cause if you're gonna rebuild it you may as well redo the valve guides too (unless they're magically in perfect condition) and that adds a lot of expense.)
a1/a4/a6 will all fit. the a6 has a slightly different cam that's good for a little HP boost. (2-3hp with no other mods done to engine)Originally posted by jimmybean21 View Postwill a F23a1 head fit?Officially "hilarious mad sarcastic"! Thanks CB74christ for the recognition of my work.
Originally posted by Mitch View PostCheck and make sure you dont have a burnt valve first. If its just that then replace it and call it a day until the next problem occurs.it a A6 in the car now. how hard is it to replace the burnt valve and how do i figure which one it is.Originally posted by lost_accord View Posta1/a4/a6 will all fit. the a6 has a slightly different cam that's good for a little HP boost. (2-3hp with no other mods done to engine)
it was cheaper for me to get a used head that get it worked. i would go pull a used one look at the valves make sure they all look good and give that puppy a good cleaning i used oven cleaner the crap just fell off it looked newkiss my grill
Members Ride
