car wont start
    car wont start
    accord lx sedan drove to the mall today wake around came back to the cb in boiut 10-15minz turn the key and wont start. i have too blown fuse for cooling fan and sum other shit my battery is good not even a yr old my altenator is good just got it check bout 3weeks ago basically nothing comes on no prove-out lights dome lights nothing i need help ASAp
    BREATHonda
    no dash lights with thi ignition on? if so, check the 2 fusible links under the hood the 80 amp battery one and the 50 amp ignition one....... Sounds like one or both of those could be your problem.
      check your ground cable on your battery
        i had my oil pressure light on for about a month now i checked everything that had to do with the oil pressure and they r fine and i also change my oil and filter so would that light be the cause of my car dieing on me
        BREATHonda
          i checked the ground cable and it was loose so i tighten it up and it still wasn't working
          BREATHonda
            Did you actually check your battery or are you just assuming it's good because it's new? My last battery lasted about 6 months, then it died and I got a free replacement under warranty.
            Also, as long as you're asking for help, would you mind using better spelling and punctuation?
              how about i wont use better spelling!!!!!! and yes i tested the damn battery im not a noob tuner
              BREATHonda
                LOL, I didn't think you would, but then you used good spelling and punctuation to say you wouldn't. Anyway. Just that it makes it easier to read.
                  Also… last time I had a loose ground terminal, tightening it didn't work, I had to replace it. Best to check the connection on the other side of the terminals. Maybe file it down a little.
                    Spelling better yields better answers, and people are actually trying to help by telling you to double check the battery, But since you are not a noob tuner why are you even asking for help for such a simple problem.
                    1993 Accord EX
                    2011 Subaru STi
                      car problem
                      Having problem with your car? The scariest thing that can occur to a lot of people is that their vehicle will stop working. Not only does it cost a bunch of cash to pay the mechanic to repair your car, but you will also be without a vehicle until you can come up with the money to do so. A payday cash advance can help you pay the mechanic and get you back to work quicker.
                        try giving your starter a love tap
                        http://sphotos-b.xx.fbcdn.net/hphoto...96086673_n.jpg
                          Possible it could be your main relay, but definitely check grounding points on the transmission, water pump housing battery and group points on either side of inner headlight wells, as well as both foot wells in cabin. If you see any corrosion, clean it off with a wire brush and make sure everythings connected. also, inspect fuse box and test for voltage there to make sure you are getting continuity.
