confusing h22a4
    confusing h22a4
    whats up every body hope someone can help me i have a 93 accord with a H22a4 that has been converted to obd1 with brand new obd1 dizzy injector obd1 wiring harness and a p28 ecu chipped by phearable.net wen i crank it up it idles like a 500 rpms or lower. it has no low end power late throttle responds and acts like it out of time i checked it and its dead on i unplugged the TPS and it does the same thing. I unplugged the Oxygen sensor and the egr valve and i checked for IM leaks and didnt find one. please help
    h22a4+p2u5 trans+8000rpm= 135mph in 4 gear
    recheck timing with service connector jumped.
      thats the lil plugg in thing hanging under the glove compartment rite?
        Right.
        Are you throwing a CEL?
          the CEL stays on even wen i try to get the codes it dont blink or any thing
            Are you doing it properly? Jumping the service connector?
            If so, your ECU might be done.
            See if you can get your hands on a P13 to swap in there. If that fixes the problem, that will be your answer.
              yeh im gone try that cause i have done that penty times before and never had that problem
