hey guys, quick question. My f22a1 was running like shit when i got it. it would idle irratically and vibrate like a bitch. well, i replaced my tube seals and valve cover gasket about 3,000 miles ago (car now has 199,800) and it still vibrates a little bit while idling. should i replace my plug wires also? o yea, forgot to mention that i also replaced my sprark plugs too. any insight would be helpful.
Idle Question
From my idle problems.
I cleaned my IACV (On the plenum) and it helped a lot with the funky idle.
changing plugs help too because if you had oil leaking into the plugs(Since you said you changed your valve cover gaskets and stuff) the plugs become soaked and it does mess with the spark and cause the car to fight for spark.
changing plugs wouldn't cost that much and it would help. I just changed mine and it helped a lot with idle.
