The car was running fine yesterday morning & later that afternoon I had to run an errand. When I started the car, after about 5 seconds, the car shut off as if their was no gas in the car (btw there is gas in the car)
So I tried starting it & it would only crank so I checked for spark & there wasnt any and then I checked to see if I could hear the fuel pump & I couldnt hear anything... Something I noticed is that the engine light stays on & the sports light didnt even come on when I put it in ACC mode. I removed the carpet to check the computers to see if they were throwing any codes & there was no light at all (my ECU/TCU come with a little window)...in the past when I checked for codes, there was still a light that would blink at least once when I put it into ACC mode.
So im not too sure if there is a short somewhere that burned my ECU & TCU??
Or could it be another problem that i'm not aware of?
At first I thought it could be the ignition module in the distributor. But after not hearing the fuel pump either, im lost on what it could be.
Any help would be appreciated
TIA
TIA
