exhaust pipe?
    exhaust pipe?
    so my friend gave this muffler with a burnt tip. not sure what kind but it has a 2.5 inlet and 4 outlet what size piping should i use? i ask because he said i should get 2.25 piping and i thought i should get 2.5 cause of the inlet size. what should i do?
    You can use 2.5" or 2.25" piping.
    2.25" is ideal for a pretty stock F-series.
    If you're running an H or heavily modded F, get 2.5".
    2.5" will also be slightly louder than 2.25".
      What engine do you have? You willl loose throttle response at low rpm with 2.5" piping and not enough gain at higher rpm to make up for it. I would definitely go with 2.25" piping (unless you are making 200hp+)
      Also, have you looked into generic cat-backs on ebay? They are a little over a hundred bucks and a perfect fit. That may be a better option than buying a muffler and piping and then welding it together.
        i have a f22a6 with cai and i have a header with a test pipe just want to finish the full exhaust and that was all i planned on doing. i would do the catback but he gave me this muffler.
          Unless you plan on doing more engine work, you'll be fine with 2.25" piping.
            k thank you guys
              Did you just want to cut your muffler off and get that welded on? They usually just expand the pipe or add a cheap already expanded pipe converter and weld that inline.
              AD5OS
              FOLDING@home
                i am going to run the 2.25 piping from the header back. i already have the header and the muffler just need the piping.
