what does??
    what does??
    just wondering what will the coolant temp sensor do to the car if its bad i got major wiring problem out of the sensors that go into the head under the distriber???????thank you
    Which temp sensor? there is 3. 1 2 wire on thermostat houseing. 1 1 wire under dizzy on head. 1 2 wire on the collant neck for the upper radiator hose.
    -1991 Honda Accord LX H22a-
      THe coolant temp sensor tells the ecu the coolant temp. The ecu then makes adjustments to fuel and other factors depending on other readings from other sensors. All the sensors tell the ecu information so it can make the car run according to preset specs. If the coolant temp sensor is bad you will probably run rich. Someone will correct me if im wrong im sure. The ecu will think the car is cold at all times.
        It depends which sensor goes bad. One could cause the guage not to work the other could cause the fan to never kick on. Just depends which one it is.
