Royal purple break-in oil
    Has anybody ever used Royal Purple Motor Break-in oil before? My old man used it for his V8 and I was thinking about using it for my motor, but I was wondering if anybody had any bad experience's with it?
    Where there's a will, there's a way
    Breakin's are usually meant for new motors, or rebuilt. If your engine hasnt been rebuilt, just use oil.
    90 Accord EX F22a1 Auto R.I.P.
    2011 Mazda 3 Hatch 2.5L GS sport HELLO!
      my engine has been rebuilt from the bottom up!! so any bad experience's?
        Royal Purple has been known to make very good stuff...
        Granted, there's no real need for "break in oil". I've always just known to use regular oil, not a synthetic, and it works fine. I broke in my L15A with regular, and then switched to synthetic.
          Thats what I recommend too. Break-in with regular oil.
            From what I've seen on rebuilds or new engines, there is a higher level of some metals...but...are these levels high enough to warrant a pre-15-20,000 mile oil change with synthetic (or pre 4k-5000 mile oc with good conventional)?
            I don't really think so. If you've got anything in your oil after a rebuild/new engine that could damage your engine...something went terribly wrong and it's not the oil you should worry about.
            If it makes you feel better to get all that out then run a GOOD conventional oil for 4000miles, it's not a bad idea, you aren't wasting a lot of cash. Then switch to a good synthetic (change filter too)...then your set to go to 15-20k with filter only changes (plus oil top off) every 5k.
            ____
              royal purple is the best product i've ever seen in my opinion ive seen it used in 12.6:1 all motor aps to 24psi boost apps no problems if you perform the break in properly
                but you can just use their synthetic it doesnt have to be the break in stuff i wont put anything but royal in my cars and trucks now i love the stuff
