ok so we sprayed a H22 a 125 i belive cuz of wrong shot...the h22 now has low compression..what may the problem be? piston rings im guessing
H22 Nitrous low compression
Originally posted by deevergote.Jesus Christ, I just deleted this quote from some noob already!
The movie is old. It is not funny. Either help, or get the fuck out.
Anyways, for all you noobs out there, 125 shot on a stock motor aint shit. Seriously. I know plenty that have run more for years. Do it right and you won't have problems.
Not a flame. Tactical leadership.
And 125 on a 10-15 year old 10.0:1 or 10.6:1 H22 is bad news unless the person doing it REALLY knows what they're doing (ensuring proper fueling, ensuring that the motor is healthy, not abusing it...)
Most idiots will blast a 100 shot on 87 octane and redline it... and wonder why they blew their motor. Those that get away with big shots know what they're doing. Those that get away with big shots aren't the type to "accidentally" use a larger jet than intended.
Not calling Mr Jenkins here an idiot... but the circumstances surrounding the damage suggest that perhaps he and his buddies aren't exactly the most knowledgeable about the power adder that they were using.
Originally posted by C91BLX7 View PostWho shit in your cheerios deev?
Plus, about 45 seconds passed since I deleted the exact same post from someone else... That's my way of saying "repost"
The age of the motor doesn't have much to do with it's health, btw. I've personally tested a few obd1 h22's that have nearly as much compression as my 11:1 motor. THen I've tested a few obd2 motors that have less than 200 in each cylinder.
And you don't REALLY have to know what you're doing. Just some simple common sense and reading a few write ups should be enough.
Oh, and H22's are far from being high compression.
Next time you or your mods see someone telling another member to fuck off in the noob section, remember to not ban them. Unless of course, you're taking the "this isn't a democracy" thing to the max and not applying yourself to the rules. I'm sure if it would have been someone like quickangel telling a noob to fuck off you wouldn't have thought twice on banning.
Originally posted by d112crzy View PostUnder those circumstances, even a 50 shot is too big.
even people who run 50 shots have taken the proper steps to ensure the motor doesnt go on them. and those people who have run bigger shots than that have a motor thats either built or know what their doing, right? not someone who put a 125 shot on by mistake.
If you read enough, you DO know what you are doing. Most of the time, people don't read. You know that as much as anyone!
And you're absolutely right. Post (and offending post) deleted. I only said to help or don't bother posting, but I guess my method was a bit harsh. I didn't tell anyone to fuck off... just demanding a contribution to the discussion, not "wut he sed... oh, and i have this 'clever' quote from a horrible movie to share too!"
A 50 shot should be done on a healthy motor. Anything bigger on an H22 (not a high compression motor, but not low compression either) should at least have steps to ensure:
1) a properly functioning fueling system
2) the appropriate spark plus for the application
3) a properly functioning and properly jetted nitrous system
4) a healthy motor
5) careful operation of the motor (bouncing off of the rev limiter while juicing is idiotic... especially if it's a fuel cut!)
Until he pulls it apart, we really can't say what it is. It could be bad rings. a blown ringland. burned exhaust valves. even a blown head gasket. The amount of info provided is limited. All we know is that the compression is low, and he overjuiced it.
1) what octane fuel was used?
2) was a compression test done before using the nitrous?
3) what RPM was the motor at when the damage occurred?
4) was this a single fogger kit? Wet or dry? A 125 dry shot could be much more detrimental than a 125 wet shot... though 125 is pretty big for a single fogger regardless.. which leads me to the last question:
5) which cylinder, or cylinders, are bad?
