need help fast...
    need help fast...
    ive recently been going through some trouble with my car....to start off i had 2 problems....i had bent valves and my car had poor acceleration and it sounded like it misfired....i took care of the bent valves and now i have to deal with the second problem...my car mostly acts up when trying to go up a hill, now i posted a thread and some of the fellow tuners told me to get a compression test and to check my igniton system....ive done all that and everything seems to check out even my injectors are fine....some guy at the shop where i took it told me that most likely i have an electrical probelm....any suggestions would be nice...
    Check your ignition timing. If you had bent valves I assume you had to replace some, so the distributor might not have been put back on correctly. After that, look into the condition of the spark plugs, ignition wires, cap, rotor, coil, and ignitor (ignition control module).
    I assume this is a stock F22Ax? or is it a swap?
    1992 Prelude S w/swapped H22A
      http://www.cb7tuner.com/vbb/showthread.php?t=120893
        ...yea Its A Stock F22a1 With 97000 Miles And I Just Replaced The Head...well I Also Replaced The Spark Plug Wires And The Whole Distributor Including The Cap And Rotor And Also The Ignition Coil...i Havent Looked Into The Ignition Control Module So Il Check That Next...thanx
        Il Post My Findings
          are you typing all caps? if yes stop it.
          next...could be a coolant temp sensor
          ____
