Replacing AC Condenser ?
    I Just came back from the shop and they threw dye in the system and turned out that the Ac Condenser needs to be changed do to leakage ,
    Is This a simple repair that any Novice can do like myself to save some money
    Thanks
    Check Out My Work In Progess . . . . .
    Just take off the rad support and push the radiator back into the engine as much as you can then after you disconnected the lines and brackets the condenser will pull up and out.
    wat?
      so do i have to take the bumper and bumper support off for this or i can do without that process, the guy at the shop mentioned having to take the bumper off etc..
      but if its that easy shoot looks like ill save myself some weekend beer money..lol
        No, Just the center peice right in front of the rad.
        wat?
          If the dryer unit has been subjected to any air, it will need replacement or your a/c may suck and not work well. The dryer soaks up moisture in your A/C.
