'91 CB7 16valve F22A6 engine came from '93 i heard i could get 10+Hp gain from a '94 prelude ECU because they also came with a F22a1 because my ECU is a '93 or a '91 should the '94 prelude ECU make a difference ? just need some advice on that info i just read . im now curious what ECU i have the '91 or the ECU thats suppose to be with the engine ill have to ask the guy that did the swap, or i can hopefully get a number off the ECU to find out
?ecu?
?ecu?
I want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
My Ride
*****;http://viewmorepics.myspace.com/inde...lbumId=2844229*****
Oja Thnx Everyone, at cb7tuner.comTags: None
So you have a 91 Accord w/ a f22A6 motor instead of a F22A1 and you are wondering if putting in a '94 prelude ECU (P12) would help give you 10+ HP? No.Originally posted by Oja View Post'91 CB7 16valve F22A6 engine came from '93 i heard i could get 10+Hp gain from a '94 prelude ECU because they also came with a F22a1 because my ECU is a '93 or a '91 should the '94 prelude ECU make a difference ? just need some advice on that info i just read . im now curious what ECU i have the '91 or the ECU thats suppose to be with the engine ill have to ask the guy that did the swap, or i can hopefully get a number off the ECU to find out
The F22a1 from the prelude was rated at 135-140hp and the F22A6 from the Accord was rated at 140hp.
Next time do you think you could take a little more time to write your question better? That was fairly difficult to decifer.
Just so you know:
Accord ECU F22A1= pt3
Accord ECU F22A6= pt6
Prelude ECU F22A1= p12
I am sure someone else will chime in and add to what I have just said though.3 CB's gone....
1 WK Overland....
Still miss the CB though......maybe one day.
thats only if
so i need to find out if the F22A6 ECU is in it or if the F22a1 ECu is inI want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
My Ride
so what YOUR saying
the F22A1 prelude pt12
is better than F22A1 accord ECu
but not better then the pt6 F22A6 accord ECU
so if i have the '93 ECU to my F22A6 its better than the '94 prelude ECUI want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
My Ride
okay doky
thnxOriginally posted by JoshM View PostThe p12 is the best plug and play ECU for the F22.I want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
My Ride
