As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Tempature Guage
    Tempature Guage
    My tempature guage is pegged on hot, what sensors will cause it to do that?
    Are you sure it's a faulty sensor?
      Common problem with cbs, thermostat should be the first one to check.
      1993 Accord EX
      2011 Subaru STi
        jumping to conclusions!
        First does the temp gauge go hot before the engine is turned on with engine cold... key on engine off.
        If so then you have a faulty sensor or a problem with wiring.
        If not and it rises normally with engine temp increasing but continues to rise and pegs on hot...
        first check for fan operation. if ok then check thermostate as it may not be opening.
        member ride thread
        DIVULGE MOTORSPORTS
          If it's truly "pegged" to high, that implies a faulty coolant temperature sensor or a bad connector/connection to me.
            yes it is pegged on hot when the engine is cold, which coolant sensor is it?
