back windows
    back windows
    well i have been wanting to ask this my cb came with the back windows not working
    so i take the door panels off n well everything looks all gravy
    i press the button i can hear it move so motor works on both sides
    but the window aint movin up or down the rails aint movin nuthin wtf
    More than likely the gear in your motor is trashed. I would take the whole thing apart and test the regulator and motor on a bench. If you get it working grease it up and put it back. Shouldn't take more than a hour or so per side.
      x2
      You might have to get a new gear or railing system also.
      Frost White CB9: EX F22A6 Stock 5spd - Click Here
        yeah, itll be easier to replace the whole new motor/regulator set.. got mine off ebay for 41shipped..
          check out your local junk yard for a window regulator/motor
            ...that could also be faulty. Get a new aftermarket motor/regulator. Like NinJa_FLiP said, you can get two for well under $100. That's just a little more than you'd be paying a JY for two used units.
              thanx never thought of that
              Originally posted by CappuccinoLX View Post
              x2
              im sorta tite with money ill c wat i can do first mechanical
              dam they charge hella money for those parts i already went n looked
              yeah but at the same time they new n beter but i dont got that kinda money rite now so ima check out the gear if it aint that ill just deal with it for a lil longer
