Bent Frame
    Bent Frame
    Last year I hit a curb that was completely burried under snow (I live in Edmonton) goin about 30mph, and I apparently bent my frame. The car pulls slightly to the right. I want to get it fixed and I was just wondering about how much you guys think it would cost, and if its even worth getting fixed. I want to get new wheels, and I dont like the fact that my tires dont wear down properly with my frame being bent.
    You hurt your suspension, not your frame. Get it fixed IMMEDIATELY. And don't ask us, since all honest shops give free estimates!
    You're probably looking at $500 at least, but you must fix this (at least get it diagnosed) or your wheel might fall off.
    You bend your frame by hitting a wall or another vehicle. An impact on the wheel won't bend the frame.
      well I got an alignment done like the day after it happened. And this happened over a year ago, so I know my wheel is not going to fall off at this point. I'll bring it in somewhere to get my suspension fixed though. Thanks for the advice.
        I also hit the curve
        here is my post
        http://www.cb7tuner.com/vbb/showthread.php?t=135160
        i had to replace Radius Rod, Lower Control Arm, Caliper, and Rotor
        I also went and replace lower ball joint and upper control arm for precaution
        I'm not done yet but make sure you get an alignment afterward
          Did it still pull right just after the alignment? The hub tends to fail gradually so it could still fail anytime. Especially if it makes noise when you jack that wheel up and spin it in neutral.
          If it's gotten worse since the alignment, you definitely know something is breaking.
            It hasn't gotten worse. It still pulled right just after the alignment. Sometime in the next couple days I will jack it up and spin it in neutral to see if it makes noise or not. Thanks for the advice.
              here is my post
              oof....yours is a little worse than mine. Mine has no visible damage at this point. All I replaced at the time was the wheel and the tire, and got the aligment done. Mine just pulls a little bit to the right and I want to get it fixed because I want to get some new wheels, and I don't like the fact that my tire does not wear down properly.
                Then, they didn't do an alignment . On the other hand, especially at low speed, the car seems to pull right because of the road crown. Last time I got an alignment I told them it was pulling right, and then they told me it was straight to begin with. They also explained that a "straight" alignment actually pulls left slightly, because on a crowned road you tend to drift right.
                Back on the first hand, some of the pieces Xclusive mentioned aren't easily visible either. If the garage just sold you a wheel and an alignment after a curb impact, I would never go back there. If the impact bent/cracked your wheel, it should have also messed up your hub at least… my 8 mph curb impact in my Mazda "only" meant a new hub.
                  funny thing is my hub is fine.... Everything else is not
                  Oh i hit the curb like 30-45mph in the rain
                    Yeah, well I was in a Mazda, and it was a low speed impact directly sideways sliding across ice.
