As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
o2 sensor extender...
    i was wondering if n e body ever seen or used this before???
    i was thinking bout try'n it out,
    wuld it keep the sensor cleaner?
    and maybe extend the life of the sensor...(i wuld think)
    or do u think its pointless??
    just curious what sum cb7 members think, thanks
    Ehh , the sensor will give false readings in my opinion.
    Also , in order to work optimal the tip should be fully exposed inside the tubes.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      x2 what ^ said.. i think those are what people use when they have an 02 sensor after the cat... when they delete the cat, they use those to pull the sensor out of the exhaust stream so the CEL will go away..
        yeah, thats what i just read, that makes sense...
        thanks
          x2 it would def give a false reading
          "The Turtle"
          DD/Trail Rig/Mud Bug
            Those work sometimes if you have a test pipe and want to elimiate the CEL from the 2ndary o2. Using it in your primary is just going to screw up your o2 sensor readings / AFRs. Not a good idea.
              google "Spark Plug Non-Foulers"
                It's a cheap cost affective way for OBDII tuners to pass emissions if their CEL light comes on for Catalyst efficiency. Sometimes it works with just one "spark plug non-fouler", but most of the time you have to double them up. You need a 1/2" drill bit to bore it out also for the 02 sensor to fit in it.
