Headlights not working!!!
    I did a minor wire tuck today and also decided to blackhouse my lights and paint the highbeam yellow. Well do to my lowbeam lights failing between the wire tuck and painting the headlights I was stopped half way on my goal for today.
    Anyway ok the highbeams still work as well as the turn signals.
    All my bulbs are good I checked them but the main problem is the low beams not working because if they don't work I can't drive home from work.
    Also the right turn signal light on the dash is lite up not flashing but lite up.
    If you turn on the turn signal the sports light flashes and the turn signal does not the is the right one. The left one works fine and does not mess with the sports light.
    All the fuses are good but depending on which one I take out some of the other lights come on and the other go off. IDK its really weird and confuses me.
    Anyway any Ideal on what it could be?
    http://www.cb7tuner.com/vbb/showpost...53&postcount=4
    Also when I tested the volts it got about 10.48 to the wires for the low beam but when you plug it in it seems to only get about 1.44.
      Check your grounds, and did you cut any of your wires if not are you sure you didn't pinch the wires. Check you signal and light combo switch also it could've went bad.
      NEW CB
      old Darkcloud : 1990 Accord EX MRT
      new
      DARKCLOUD : 90 ACCORD EX MRT
        Can any one tell me where all the grounds are for the lights?
          I have a relay on order but not for sure which relay could cause the problem?
