does any one know the specs on useing a multimeter on these?
ignition control module
it should be 1.1k - 3.3k Ohms between the single pin (blue wire) on the side, and the first pin (of the three) right next to it (light green wire)Originally posted by autowrecker17 View Postdoes any one know the specs on useing a multimeter on these?
thats all the Helms says, other than:
- disconnect all wires
- turn ignition ON, check for power at Blk/Ylw
- check that the Light Green wire shows voltage also
- check that the Ylw/Green wire is not shorted between the Ignitor and ECULast edited by cp[mike]; 06-26-2009, 09:57 PM.
