As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
tps sensor help
    tps sensor help
    My tps broke on my h22 can i swicth my f22 one on .
    Yes you can,You just have to turn the rivets into flat heads to take the TPS off.
      There is another person in this world that knows this! Thank you!
        dam dude harsh on the kid
        lisa is long gone, but sophie is here!
        i got a good feeling about this one
        im going to have to
        __________________________
        |...OVERNIGHT PART'S 4RM....||'|";,__
        |..............JAPAN.................|| ---**-)
        |_..._...____________======||_|_|__--]
        check out my mr thread
        http://www.cb7tuner.com/vbb/showthread.php?t=106541
          If you have a dremmel with a cut off wheel, you can slot the top of the heads of the screws that hold it into place, and then turn them out with a flat head. If you do not have a dremmel, you can take a pair of dykes (flush side cutters) and get under the little washer under the screw and bend it up a little. Then take a pair of good pliars or vice grips and fold the washers up by squeezing the top of the head of the screw and twist them out. Once you get the initial break free, you should be able to turn the screws out by hand. If all else fails, you can take a flat head screwdriver and a hammer to break off your old tps around the bolt holes, and go from there. I'd try the dremmel method first, if not an option then take out the side cutters or vice grips and try that. If that fails, break that bish off.
          Remember to take a volt meter to your new tps and calibrate it to .45~.5v KOEF (Key on, engine off) at closed. It should be 4.5v wot (wide open throttle). Take your volt meter and you have to pierce the wires going to the tps and measure the voltage. Measure between ground. You should have one wire that is 5v, one that is 0v and one that is .1-1v. You need to measure between the ground and the .1 to 1v wire to calibrate correctly. If you do not do this, you will get some funky shit going down (I love beer)
          -Big3racing.net-
          My Build Thread. Many pics.
            Harsh how? For thanking him for actually knowing something? Everyone else says "naw dude you gotsta buy a nu throtel bodie cuz itz rivetted on dere"
            You can also use a hacksaw blade to notch the screws (they aren't rivets, just headless screws)
