I think my oil pan is leaking around the seal. I am looking at my Haynes Manual and it looks straight forward for the most part. But they Mention removing the oil pick-up tube. Do I really need to remove this just to replace the gasket?
Oil Pan Gasket
Originally posted by batever View PostNo you don't need to remove the oil pickup tube for this.
Use the search key on oil pan and look at the most recent results, there was a thread just 2 days ago on this with detailed procedure.
@chillin943 the Haynes Manual said to remove the cross member and I have a feeling like this is going to be a real bitch since I live in Ohio where the use lots of road salt.
Thanks for the info!
Originally posted by pacmanlives View PostThanks for the info I did find the post!
ironic ive NEVER owned a haynes manual.
Originally posted by batever View PostI live in MA where there's lots of road salt too but I didn't have a problem with the crossmember. Just that the bolts were killingly tight so I had to use my big 4' long steel pipe over my breaker bar to break them free.
Originally posted by SEXXIILADY712 View Postleave the crossmember off for the next time
I'll put it back on when I get around to it, but it's definitely not a top priority right now.
Originally posted by chillin943 View Postnot sure that's safe. i mean it is on there for a reason
My understanding is that it's safe to drive without it, primarily it prevents the engine from dropping out if the motor mounts completely blow out and also it has a nice tow hook on it. But it's not essential for the frame or safety or anything. But I will put it back on when more important things are done and I have time.
hehe im changing my oil pan gasket as we speak. remember that stupid torque converter plate has to be removed to take down the oil pan. but man i coiuldnt put it back on, so i grinded it down and put it back on lol.
I used a new honda gasket and some black gasket sealer.
Im doing the valve cover gasket as well.
Overall its straight forward. easier to take it apart than put it back together. Clean the surfaces before you put it back together so that the seal and the gasket sealer will bond nicely.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
