I was driving and as I was coming up to the left turn lane I needed to get in, I took my foot off the gas and about three seconds later my RPMs dropped completely to zero, at this point I was still rolling towards the stop line. Then three seconds later the oil light and battery light came on. I then put my foot on the brakes and stopped the car. I then tried to restart the car...and the engine turned, but would not start. I waited about ten minutes, then I tried again and the car started, but my idle RPMs were at about 400. I then drove it to my house, which was less than a block away. I can't figure out what happened, the car still starts fine, just my idle RPMs are at 300 or 400. I am confused by the fact that the car was still rolling and my RPMs were completely at zero. If anyone has any ideas what could possibly have happened, it would be greatly appreciated.
Engine Dies While Driving. Help diagnose this.
Check it:
- Main Relay
Turn the car to pre-ignition , if you hear a click under the driver side under dash then your main relay is fine.
- Ignition Coil
Will not start at all
- Fuel Pump
Turn car to pre-ignition , if you hear a loud hum on the gas tank area , then your fuel pump is fine.
- Ignitor
Car will die once the car has warmed up or atleast the distributor has heated up. It will restart again once cooled down.
- Grounds
Will make car go poo-poo. Possibility it will start or not start at all.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
How were you able to tell that the rpms were at 300 or 400...were you just estimating, because there are no marks between 0 and 500. The car dying then restarting after cooling down and the tack cutting out all point toward the igniter. The low idle...well, honestly, I suspect you're reading the tack wrong...the engine probably can't even run that low.Originally posted by capo_status View PostI was driving and as I was coming up to the left turn lane I needed to get in, I took my foot off the gas and about three seconds later my RPMs dropped completely to zero, at this point I was still rolling towards the stop line. Then three seconds later the oil light and battery light came on. I then put my foot on the brakes and stopped the car. I then tried to restart the car...and the engine turned, but would not start. I waited about ten minutes, then I tried again and the car started, but my idle RPMs were at about 400. I then drove it to my house, which was less than a block away. I can't figure out what happened, the car still starts fine, just my idle RPMs are at 300 or 400. I am confused by the fact that the car was still rolling and my RPMs were completely at zero. If anyone has any ideas what could possibly have happened, it would be greatly appreciated.
The needle was hardly above zero, it was not as high as 500. But as far as I know that could be completely unrelated to everthing else.Originally posted by Grin0048 View PostHow were you able to tell that the rpms were at 300 or 400...were you just estimating, because there are no marks between 0 and 500. The car dying then restarting after cooling down and the tack cutting out all point toward the igniter. The low idle...well, honestly, I suspect you're reading the tack wrong...the engine probably can't even run that low.
After I let it idle for 10-15 seconds the RPM goes up to about 1000Originally posted by Grin0048 View PostHow were you able to tell that the rpms were at 300 or 400...were you just estimating, because there are no marks between 0 and 500. The car dying then restarting after cooling down and the tack cutting out all point toward the igniter. The low idle...well, honestly, I suspect you're reading the tack wrong...the engine probably can't even run that low.
Well it would be pretty obvious if the engine was actually trying to run that low...the tack isn't reading properly which would indicate igniter (consistant with the car dying and restarting) or maybe a problem with one of the sensors in the distributor...are you getting any codes?Originally posted by capo_status View Posthonestly, its not, other than the fact you can hardly hear the engine, it sounds like nothing is wrong at all.
Same problem.. sort of
I had almost the same problem as the first post but my car did not start again. I was driving and got about 5 minutes from my house when of course the oil light and the battery light came on. I cut the car off for about 30 seconds, I restarted it and the lights were off then about 30 seconds to a minute later the rpms went down to zero and the car slowly died. I tried to restart it a few times and no luck. I to restart it again about 10 minutes later with no luck. I towed it home got it in the garage and let it cool for about an hour, so at this point the car had been cooling for almost two hours and again no start! When I turn the ignition on (not trying to crank it) the battery light and oil light stays on but the CEL light and Airbag light goes off... Any suggestions? And yes it sounds like its turning over just no cranking. Thanks for any help.
BTW its a 93 accord EX, F22, 5spd blah blah blah
