Alright, my car's coming up on a 30k service here pretty soon and I have a few questions. First, let me just post what I have as need to be done at a 30k service
I'm really wondering about some of the things that are on this list. That majority of the things listed I can do easily at home and save a ton of money. However, there are a few things that I would have to have a shop do.
Inspect valve clearance
The only "check" that I'm iffy about. For those that have done this before, how difficult is it? I've read the manual on the procedure and it seems somewhat involved. Is this something that really can get moved around over time or is this just a point added by Honda to cover their asses?
Replace Distributor cap, rotor and inspect wires
Inspecting it I don't see any kind of large amount of wear and tear so can I wait to replace this or should I do it anyway.
Set ignition timing and adjust cambelt
I don't have a timing gun, so if this really needs to be done it would have to be done by a shop. Is it necessary?
So there are my questions. I'm really hesitant to take the car to Honda for a $300 service when all I'm really getting is about $50-$70 worth of parts and fluids which I can easily change myself. However, if some of the things I mentioned really do need be checked/service would it be possible for me to do the rest of the maintenance and have Honda only do those few things?
Thanks for the help.
Change Engine Oil & Filter
Change Tranny Fluid
Replace Fuel Filter
Replace Air Filter
Replace Spark Plugs
Replace brake fluid, check hoses & lines
Adjust parking brake
Replace clutch fluid, clutch operation, adjust freeplay
Adjust all belts & inspect power steering fluid
Replace engine coolant & check hoses belts
Adjust alternator belt
Rotate tire and balance
Lube door, hood latches and hinges
Inspect crankcase emissions
Inspect front & rear pads, rotors and calipers
Inspect suspension mounting bolts for tightness
Inspect exhaust system
Inspect tire wear and set tire pressure
Inspect battery and clean terminals
Check wiper blades and windshield washer fluid
Change Tranny Fluid
Replace Fuel Filter
Replace Air Filter
Replace Spark Plugs
