I have a 90' CB7(OBD0). I just swapped the F with an H22a4 (OBD2). Does it matter if i use an OBD1 or OBD2 engine harness? I got an OBD1 ECU so should i use an OBD1 harness or use the OBD2 harness because of the Engine?
Wiring Question
If it is a 1990, then it is OBD1. Generally, people use the F22A harness on the H22A (whatever version, all the sensors line up fine) and then all you have to do is switch to the OBD1 injectors and wire in the usual 4 things - IAB, 2 VTEC, and knock. Since you have the OBD1 ECU, that would be what I recommend.Originally posted by Juicy_J View PostI have a 90' CB7(OBD0). I just swapped the F with an H22a4 (OBD2). Does it matter if i use an OBD1 or OBD2 engine harness? I got an OBD1 ECU so should i use an OBD1 harness or use the OBD2 harness because of the Engine?1992 Prelude S w/swapped H22A
I think that was or is for civic's and integra'sOriginally posted by jdm_inspired View PostReally? I thought 1990 was obd0. and 91-93 was obd1.
Wrong. I had a 1990 Accord EX that was built in December of 1989, internal coil, and was OBD1. The CB7s were all OBD1.Originally posted by Juicy_J View PostOBD 1 Accords have an external coil. I have an intrernal, so my car is OBD 0.
The external coils started coming in 1992 Accords, and had nothing to do with OBD1 vs OBD2.1992 Prelude S w/swapped H22A
