will celica rims fit?
    the above rims have a 4x114.3mm bolt pattern - I can't find out the offset.
    (they are 14" celica/supra rims)
    I need a spare set of rims to put winter moccasins on, and would like to buy these for my '93 EX.
    I don't know they will clear all the brake and hub hardware.
    it looks like it has some offset. i think they will work, just dont use massive tires like those
    miss my turbo cb7
      just look for accord 15" 4 lugs and put some nice tires
        MKII Celica Supra wheels on a CD5:
        http://www.cb7tuner.com/vbb/showpost...4&postcount=23
          Originally posted by JoshM View Post
          damm toe in the rear. holy shit
          miss my turbo cb7
            Excellent - the ones I'm looking at are listed for 100 bucks for 4 of them, I need to confirm their condition and make a deal if they are ok.
            I like the black accents on the center/spokes of the ones you linked to.
              $100 isn't bad at all, if the wheels aren't bent. Are tires included?
                Nope, tires aren't included. I'll be putting some 185/70r14 Michelin X-ice tires on them, I've been absolutely impressed with the winter performance of these - my old civic has been rear-ended countless times since installing a set of 13 inch ones in the winter!!!
                I'm going to look at them tommorow if my schedule allows, I'll be checking for bends, curb damage and good bead areas.
                  no, they hit the brake caliper...I tried last week
                  fyi...celica/supra rims
                  *added
                  I suppose with a spacer...but you'll fuck your bearings...so either way...yes they are the right bolt pattern but they won't work
                  ____
                    Angle grinder will take care of that.
                    Originally posted by chessboxer
                    We know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
                    Bought From: Slammed4thGen TypeG x2DeevergoteBillKisme
                      I'd rather not grind them - it'll bicth wheel balance.
                      If it was a center/hub size issue, then I could hone it out.
                        Grind the caliper bracket not the rim.
                          ROTFLOL,
                          Thanks, I shoulda thought of that.
                            People will argue against doing it, but I did it to fit my ITR's on, I've had no problem with it at all.
