can i use my stock flex pipe?
i bought used headers...
It should've come with one. You'll need both the header and the downpipe. Even the tubular F22A4 exhaust manifold (which looks similar) doesn't line up, because the flanges are different. If you have the downpipe without a flex pipe, you'll need to weld one on with a flange for bolting to your catalytic converter. An exhaust shop should be able to handle that for you.
i just bought the part that comes out from the engine.. i got it for $20Originally posted by 93accordfreak View PostIt should've come with one. You'll need both the header and the downpipe. Even the tubular F22A4 exhaust manifold (which looks similar) doesn't line up, because the flanges are different. If you have the downpipe without a flex pipe, you'll need to weld one on with a flange for bolting to your catalytic converter. An exhaust shop should be able to handle that for you.
it a hp racing header
