kinda found where oils leakin. still need help
    ok i "cleaned" everything under my engine so i could find the source of my oil leak...well this is what i found. i Cant tell whether its leaking from the oil pan gasket or if its leaking from the transmission...which would be the rear main seal...any suggestions?
    Rear main seal. Transmission has to come off to do it. Ignoring it could be risky.
      aHH....know how hard it is?....
        Hard?
        Hard is a subjective term that really depends on your experience level and the tools at your disposal.
        Is it tedious, yes. Tedious in that there are several steps that must be followed in order to remove the transmission.
        Some words of advice, if you're planning on doing this, obtain a cherry picker or a transmission jack so you can eliminate about 2-3 hours from the install time.
        1997 Honda Accord EX-V6:
        Originally posted by James Matteu
        You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
          ok...while im doing this...."my car is auto"...should i jus conv. to manual to get it out of the way?
            converting to manual isnt quite as simple as dropping in a m/t and bolting the pedals, shifter, and hydraulic assemblies up and off you go.
            if you're worried about just removing your auto and replacing a seal then i dont think you should jump into converting to a 5spd unless you have someone helping you that knows what they are doing and have VERY THOROUGHLY read thru the trans swap stickies.
              sorry, i should have stated that i have done an auto to manual conv. i did it on my e30 325is, but i know that rwd's are easier...i can do that no prob.. but i have never replaced a rear main seal. thats why i asked...i dont know if u ment it but ur comments are a little insulting considering u didnt ask me any questions. but thanks for your support
                what makes you think rwd cars are easier to convert? one less driveshaft?
                rear mains on our cars are cake. sorry if you got insulted but it sure didnt sound like you had much experience by the question you asked.
                seriously though. read the 5spd swap stickies.
                unless you buy some nice, pricey mounts you will end up cutting out and relocating a M/t mount, along with possible drilling and tapping new mount holes, and wiring your shit to work correctly.
                removing the trans on our cars is simple enough that when you are ready to swap it is the least of your worries.
                just fix your leaks first so your motor stays alive.
                  this job pays like...4 hours for a shop to do it...it's like 3-400 dollars? all for one seal.
                  You have to pull the tranny...not easy...a lift would really help
                  ____
                    The auto to manual swap is easy. The most complicated part is welding the manual transmission bracket in place of the auto bracket. Otherwise, it's just bolting on parts.
                    the rear main seal is not extremely difficult. As it has been said above, dropping the transmission is the most complicated part. It's a fair amount of work, but not difficult work.
                    Invest in a Helm manual, and you'll be set.
                      ahh that sux...what if i jus got an auto tranny out of a lude or somethin will that go on directly?
                        You'll need to tap a hole in the tranny, I believe. I may be wrong, since I'm not as familiar with auto, but with the manual H tranny, you have to do that.
                        Seriously, it's not that much work to do.
                        Another option is to go to ESP (they have a Member Shop here) and buy their conversion mount.
