can i run this ecu on my lx 93 accord. i found a chip for it.
po8
What do you mean by "found a chip for it"?
The P08 came from the Civic VX. I'm assuming it's quite similar to the P06 that is commonly used, so I'm sure you'd be able to use it.
However, your post makes me think that you discovered a "P08 Chip" somewhere... and that is a BAD idea. If you use any ECU other than the one that is made for your car, you need to have it tuned especially for your particular engine, or it won't do anything good. It may even damage your engine.
Yeah sorry forgot to mention that, the P28 or P12 is your best bet. But depending on what you are going to do and set up is just stay with the stock P13. I don't know to much about whats what with ECU's, if your serious about it then you can check out crzy tune in the member shops.
"The Turtle"
DD/Trail Rig/Mud Bug
The P12 is no good for the H22. The P12 is ONLY good for the F22A1.Originally posted by 93F22A6 View PostYeah sorry forgot to mention that, the P28 or P12 is your best bet. But depending on what you are going to do and set up is just stay with the stock P13. I don't know to much about whats what with ECU's, if your serious about it then you can check out crzy tune in the member shops.
Please stop typing like you're texting your girlfriend.Originally posted by phayze View Postwell i no the p28 are wat ive seen for the h22
