Radio blowing tcm?
    Radio blowing tcm?
    I have a 90 EX that I picked up for $200, it had a bad TCM and the body was rough. I blew out reverse on my own, but that's besides the point. I got a new (used from e-bay) TCM in the mail today and within my first 15 minutes of driving to work, it stopped working and my dreaded "s" light came back on. I got off work, came home, unplugged it, and plugged it back in, and made sure my radio was off, and its been working ever since. Do you think the aftermarket radio could be causing TCM's to get fried? Its a fairly cheap head unit, and its hardwired in. Think its wired wrong? I'm stuck on this one...
    if you suspect your radio causing your tcm to go bad, unplug the radio...drive it and see what happens...
    i think you might have a tranny problem...but thats just a guestimate...
      I can't unplug the radio, I would have to cut all the wires as it is hardwired in (Meaning that there is no wiring harness).
      I know I lack reverse however the rest of the tranny seems fine...?
        seems to me like your transmission is done..as far as reverse...i've seen a handful of this happen on accords...but you just gotta start testing stuff to make sure though, or take it to a shop...
          if you want to test the radio. just unplug the harness from the radio that it's attached too.
          Yes my name is Dang, Don't use in vain
          1992 Honda Accord EX (Coupe/Bordeaux/Auto)
          1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
          2008 Honda Accord EXL (Coupe/SanMarino/6spd)
            did you replace the oil in your transmission? go get some honda MTF and try it again...
            AD5OS
            FOLDING@home
