Question
    Question
    my engine is running very well. but after a quick drive and it is shut off and i get back in to start it 1 doesnt start or putters reall quick and just turns over . so i wait a minute and it starts right up what do you think EGR or what ? get at me
    I want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
    My Ride *****;http://viewmorepics.myspace.com/inde...lbumId=2844229*****
    Oja Thnx Everyone, at cb7tuner.com
    too many posibilities. loss of spark or fuel.
    when it wouldnt start did you hear the fuel pump kick on? could be intermitent problem w/ pump or main fuel relay.
    when is the last time you service the car as far as tune up? plugs, wires, dist cap, rotor, button etc. if you cant remember a good tune up should be in the works if you can afford it.
    are the terminals good and clean on the battery, if they are corroded you could have intermitent starting issues.
    its just going to be a process of elemination, start with a haynes or chiltons or even better factory trouble shooting tree or manual.
    i had this issue on my recent cb and replaced the dist cap/rotor and button and it corrected my issue. on my old cb i had it was corroded battery terminal the wires were eaten in half from the corrosion.
    good luck hope its something simple.
    (note: buy ngk if you replace plugs/wires)
