how to
    how to
    how do i get the fork off the front struts ??? i looked and used the search bar and can someone explain what are spring rates cause im looking at lowering my cb but i don't want to bounce like a low rider the spring rate for the springs im looking at are . front .246lbs/in ad rear.162lbs.in plz let me know ??
    There's a bolt on the back side of the fork that clamps it to the strut, loosen that and you may have to mess with it a bit for it to slide off.
      isn't there something you can simply loosen or tighten to raise and lower your cb7?
      i know it sounds dumb but that's what i've been told.
        Check out this thread. Should answer all of your questions.
        http://www.cb7tuner.com/vbb/showthread.php?t=179
          Not on a stock suspension.
