Is it possible to convert an auto cb7 to manual? And if so how much work does it involve other than the obvious tranny swap?
manual conversion
read this and you'll get a understanding of what you'll be going through.
http://www.cb7tuner.com/vbb/showthre...=&threadid=588
that's what i plan on doing in the future.Originally posted by Zmatt View PostThanks! It seems like a lot of work. Do you think it's worth it? I guess if I want to get the 200hp H22 then I have to do it anyways, so I might as well do the tranny swap when I do the engine swap.
Yes my name is Dang, Don't use in vain
1992 Honda Accord EX (Coupe/Bordeaux/Auto)
1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
2008 Honda Accord EXL (Coupe/SanMarino/6spd)
If I buy an H22 with the manual tranny, will it come with all the parts I need?Originally posted by vietkid_2006 View Postthat's what i plan on doing in the future.
I have been eyeing this one:
http://www.hmotorsonline.com/shop/sc...age&item=30017
Right nwo I run stock F22a1 with auto transmission. It says complete changeover, but does that hold true if I need to switch to a manual?
no you still need the clutch pedal, the manual brake pedal, the hardlines a master clutch cylinder, a 5spd transmission mount bracket, a driver side axle because the auto one is a one piece axle and the 5spd one is two pieces. clutch and flywheel.
that thread i gave you has a parts list i'd double check that just incase i missed anything.
I am starting to think the CB7 is not worth it. I wouldn't do it unless your F22 is dead.p12 on sale:
http://www.cb7tuner.com/vbb/showthre...46#post2245646
Bisimoto Heat-shielding Intake Manifold Gasket and Rear Engine Motor Mount for sale:
http://www.cb7tuner.com/vbb/showthre...95#post2246795
cb7 aint worth what??Originally posted by akburst510 View PostI am starting to think the CB7 is not worth it. I wouldn't do it unless your F22 is dead.
one day and a new engine??
there are thousands on this site that say otherwise.
CB7 is very worth it.
Bought from: Bisimoto
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
It's NOT that much work. Welding one bracket... or buying a mount from ESP. The rest is just swapping over parts. If that's too much work, you've picked the wrong hobby!
The H22 doesn't know what transmission is attached. They are no different between auto and manual. The F20B is the only engine that we can put in our cars that had less power in the automatic versions.
they do make h22 and auto trans too.Originally posted by Zmatt View PostThanks! It seems like a lot of work. Do you think it's worth it? I guess if I want to get the 200hp H22 then I have to do it anyways, so I might as well do the tranny swap when I do the engine swap.
