how difficult of a task?
    how hard is it to disconnect the drive shafts so i can pull the motor and tranny out together? would it be easier to remove the shafts from the tranny or from the wheels? .. i see the DIY on this.. but it really does not answer my questions
    You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
    Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
    you pull from the trans side.
    COUPE K24
      ok thanks.. in that case.. how is that done? .. the diy on here is for removing it from the wheel well not from the tranny
        You have to pull both ends out. You pop the lower ball joint and undo the axle nut, and swing the hubs off and out of the way. Then you gently pry the axles out of the transmission.
          alright thnxs
