How much boost
    How much boost
    Just wondering how much boost a stock f22a4 with a6 manifold can run without major concern if the motor is in good shape?(auto trans.)
    Also would like to know any parts people have fabricated(or does someone make the pieces) to put a turbo on a 93 accord?
    Thanks in advance.
    Having a small cam is like having a small dick every time you go to use it you wish it was bigger.
    It's difficult to tune the ECU for an automatic. That's the main reason you don't see many boosted autos on here.
    The F22A can hold roughly 10psi if it's in decent shape. People have pushed it to 14 with no problem, and I've seen some reach 20... but that's REALLY asking for trouble. The rule of thumb is 6-10psi and you're relatively safe.
    Keep in mind, you're going to want a GOOD tune (done by a pro, because you clearly don't have the knowledge to do it yourself yet!) and a properly sized turbo. Don't get a cheap small turbo, as they produce more heat than a properly sized one... and heat will destroy your engine real quick.
    Check the Forced Induction subforum of the Performance section. You'll find info on all the parts you need in there. If you need someone to spoon-feed you every little part that you need, then this is NOT the project for you!
      Actually I do have knowledge I do the speed density tuning on my camaro using EFI Live, Im just new to the accord market and was wondering about things like the ECU and cutting and fabing of things or parts people have used to put a kit on the accord but I promise no spoon feeding here.
      Thanks for the info.
        haha. deev. i think you just got told
          there's a bunch of turbo cb guys locally you should check out first hand. later.
          Avoiding dirt at all costs
            It's a reasonable assumption that someone who asks for an exhaustive list of necessary parts wouldn't be familiar with ECU tuning!
            If you want to go cheap, look into using a DSM exhaust manifold. They're easy to come by, and are much less expensive than a true tubular manifold.
              Also would like to know all the parts I would need to put a turbo on a 93 accord?
              Thanks in advance.
              how much boost depends on what type of turbo you use and how efficient your setup is. 10psi on one turbo vs 10psi on another turbo could be a 200horsepower difference on the accord.
              parts: exhaust manifold, turbo, downpipe, wastegate, blow off valve, intercooler and piping, oil/water lines for turbo cooling, fuel injectors, engine management.
                Thanks guys...will prob start on a turbo build Saturday.....only Q is can I do anything to keep the car an auto?
                Deev I will post pics. since I don't know what I'm doing(J/k)....but I will post pics.
                  Thanks for the info....I have a turbo car but I was just wondering about any special pieces people might have made....all of the items mentioned above is understood.
                    haha, the EXACT boat im in. So far all i have really learned is the ecu tuning on an auto is much more complicated. ill be keeping up on your build to learn more for when i start mine.
                    Soon to have the first *Bottle Fed Accord* in MI!
                    Vouch For: fatboy1185
                      Everything has to be custom besides the manifold. You can use F22 or H23 aftermarket turbo manifolds. You can also use stock or aftermarket DSM manifold(1 and 2 gen Eclipse/Talon)
