so does the 1992 accord ex come with the a4 or the a6?
92 ex question?
Correct, if it's not that big of a deal you can use your old stuffOriginally posted by kirk90 View Postk thanx! im putting an a6 into my 90 accord and people say that i can just use the old intake and dist. and wont have to make any other g
changes really. its for my grlfriends car. im gonna use the intake from the a6 in my prelude.
...? Not sure on this one, why not just look at the stamp on the block? Next to the timing/flywheel view hole where the tranny and motor meet...Originally posted by kirk90 View Postso then the car im gettn the engine from is from the 9th month of 91. so does that mean its an a6?
It should tell you what engine is in it.Originally posted by kirk90 View Postso then the car im gettn the engine from is from the 9th month of 91. so does that mean its an a6?
Look to the left of the header/exhaust manifold, under the distributor. There will be a flat spot with F22a_.
("_" will be replaced with a number)
well im gettn the engine from B@R autowrecking in oregan. on the listings of parts it said it had 91,000 miles on it and 200 comp. across. ive been lookn for an engine for my girls 90 ex for a bit and ran across this one. i orderd it without knowing it was an a6. they wantd 350 for it and i bought it. when i went to order timing belt,waterpump kit schucks said it was an a6? so i did some calln and thats what im gettn. so i will swap out a6 im,dist, ect. for the a4s parts and just use the a6 im for my other honda which i drive. later will get a6 ecu and cam ect.
