anybody know what is the top dead centre sernsor and where i could find it?????????
TDC sensor
It's in the distributor, either rebuild or replace the distrbutor first. If it comes back on check for resistance at the ecm between b13 and b14, should be between 260-500ohms. If no resistance, Repair open in ORN/BLU and/or WHT/
BLU wires. If yes, Check for continuity to body ground on B13 terminal.
If continuity exist,Repair short in ORN/BLU wire between ECU(B13) and distributor connector. If no,Substitute a known-good ECU and recheck. If symptom/indication goes away, replace the original ECU.
Well I replaced the distributor and fixed that problem. Thanks!
Now on to this cruse control issue.
My cruise control switch to the left of the steering column lights up but the cruise control does not engage from the wheel switches. My odometer is also not working but my speedometer and the rest of my lights work fine. Where to begin?1992 LX Wagon
odometer runs off the VSS signal.
member ride thread
DIVULGE MOTORSPORTS
not if there is an open circuit in the cluster or between the ecu and the cluster. The signal comes in the cabin and then splitsOriginally posted by 4U2H8ME View Post^^^If it were the speed sensor, he would be getting code 17.
member ride thread
DIVULGE MOTORSPORTS
