i had my car on running then it died and wont start anymore. once again i get no spark or fuel pressure. my fuses are good and my main relay is new. i already changed my ecu and ignition module. when i turn the key to ignition, my check engine light doent illuminate, as before my battery light didnt illuminate due to a blown fuse, but this time my battery light goes on but my check engine doesnt. im about to get another ignition module and ecu again. is there anything else i should check??
car died while running and wont start
Did your timing belt snap? Have you checked it and verified the timing is still correct?1997 Honda Accord EX-V6:
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
check your ignition swith, when you turn the key does it even krank? if so and if not then 99.9% its your swith when you turn the switch, the mini springs are blown...thats what happend to mine.
Originally posted by enVmeACCORDngly View Postif my timing belt is snapped does that mean i wont get any fuel or spark??1997 Honda Accord EX-V6:
more info
it cranks good.it ran good 2 days ago, but when i got my exhaust manifold on it ran bad, it wouldnt stay on unless i had to gas it a little so the rpm would stay up, then while i was stopped, my car just died off even though i had kept the rpm up a little bit, then it wouldnt start. it cranks, but when i turn it into the ignition, my check engine light doesnt go on.
Originally posted by enVmeACCORDngly View Postit cranks good.it ran good 2 days ago, but when i got my exhaust manifold on it ran bad, it wouldnt stay on unless i had to gas it a little so the rpm would stay up, then while i was stopped, my car just died off even though i had kept the rpm up a little bit, then it wouldnt start. it cranks, but when i turn it into the ignition, my check engine light doesnt go on.
"The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
Originally posted by enVmeACCORDngly View Postwe just replaced the main relay twice. im going to plug in my old ecu to see if anything changes. im so frustrated.
EDIT: Also just because you have a brand new main relay doesn't mean it is doing its job. It needs power and ground as well to work. Check its connections.Last edited by IAmTheNight; 08-15-2009, 08:35 PM.
