im putting in new pads but how do you recompress the piston to put the caliper back on?
compressing caliper piston
They rise their wooden pints and they yoik and sing
And they fight and dance 'till the morning
Dont forget my MRT for my 1992 Honda Accord LX
Originally posted by deevergoteEverything in Japan is made with carbon fiber and used panties.Tags: None
bump
2 ways that you can do this. (one i'm prob going to be bashed for...)Originally posted by J3wman View Postim putting in new pads but how do you recompress the piston to put the caliper back on?
1. There is a bleeder screw on the side of the caliper. Unscrew it to let the pressure out and make sure that your reservoir doesn't run dry. Change the breaks then re-bleed your line.
2. You could take a c-clamp and clamp the piston back down. *You risk blowing a line this way)-Lance- (Formally known as H0ndaspyd3rLM)
Originally posted by H22Artmanif he still disagrees. well...... buy him a pink sweater and tell him to go buy some curtains.
Bought from: lo_dit, 924dr, Fatman88, 91project, noobcake, loud92cb7Originally posted by deevergoteI posted a nude photo of myself on cd5tuner.com... it broke the site.
٩(•̮̮̃•̃)۶
thats what i thought u had to do damn it i rrreeeaaalllyyy dont want to bleed my brakes, guess i gotta
Interesting Failure
I am assuming that you know someone this happened to or this happened to you. I am curious if there were any other contributing factors or if the C-clamp was the approximate cause of the line failure. I have been C-clamping my own brake calipers since 1999 and have not had one single problem. I do take my time, i.e. I give the Brake Hydraulics time (about 10-20 seconds) to push some fluid back to the Brake Fluid Reservior after each 1/2 turn.Originally posted by H0ndaSpyd3rLM View Post...*You risk blowing a line this way1997 Honda Accord EX-V6:
Originally posted by James MatteuYou have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
this is how i did it and its completely safe and fast.
1) unscrew your brake fluid reservoir cap.
2) then take your old pads and place them over your caliper piston.
3) grab a "C" clamp and have one end press against the old pad and the other end on the back of the caliper.
4) twist tight until the piston is back in place.
A guy was in a rush when he did his. His brake lines were in horrible condition and i'm surprised that they made it to that point. I am unaware of the OP's brake lines (ie what condition they are in) so i was giving a warning.Originally posted by James Matteu View PostI am assuming that you know someone this happened to or this happened to you. I am curious if there were any other contributing factors or if the C-clamp was the approximate cause of the line failure. I have been C-clamping my own brake calipers since 1999 and have not had one single problem. I do take my time, i.e. I give the Brake Hydraulics time (about 10-20 seconds) to push some fluid back to the Brake Fluid Reservior after each 1/2 turn.
I personally have been "C-clamping" all my brakes on all my cars.
٩(•̮̮̃•̃)۶
Use a big (6 or 8") c-clamp. They cost about $7.00
There is *no reason* that using a c clamp on your *front* brake caliper pistons should break a line unless you have seriously degenerated lines. Or maybe if you have degenerated lines and an ABS system with an ABS booster--I don't know much about ABS boosters. And there is no need for a special tool to do this, just use a c clamp. Make sure your master cylinder reservoir isn't going to overflow as you tighten the clamp. Turn it like a turn, then check the reservoir, then turn it another turn---
If fluid is going to leak out the top of the reservoir and you need to lower the fluid level,, just bend a metal kitchen teaspoon at a right angle and use it to scoop out a couple of spoonfuls of brake fluid into a jar. No need for a fancy siphon or anything like that.
Loosening the bleed bolt is a pain in the ass so it would be my last choice. You don't have to press it that far in to get the pads to fit, either. Plus didn't you always want to own a big-ass C-Clamp? I knew you did!Last edited by batever; 08-20-2009, 02:34 AM.
time and the hourglass....Originally posted by James Matteu View PostI am assuming that you know someone this happened to or this happened to you. I am curious if there were any other contributing factors or if the C-clamp was the approximate cause of the line failure. I have been C-clamping my own brake calipers since 1999 and have not had one single problem. I do take my time, i.e. I give the Brake Hydraulics time (about 10-20 seconds) to push some fluid back to the Brake Fluid Reservior after each 1/2 turn.
This is the way my dad taught me back in the day and it's the way i still do it now.Originally posted by ibr_adam09 View Postthis is how i did it and its completely safe and fast.
There is NO way the pressure of a C-clamp could ever be greater than the pressure of simply using the brakes. The only real worry about using a C-clamp is damaging the caliper boot if it slips off, pinching a line if you're not careful about placement, or gouging the caliper piston itself (which isn't a big deal, but even pressure across the contact area with the pad is a good thing)
Relieving the line pressure and re-bleeding the lines is overkill. Effective, but there's no need for it.
