tranny stuck in 1st! need help asap!
    so like the title says my car stuck in 1st shift noob only moves up& down but not side too side & it wont get out of 1st gear wat could i be lookin @ here?!? any help would be great guys thanks...
    2004 Accord Sedan CM6 (daily)
    Koni Yellows, Hood Bra,Splash Guards,Deck Lid,Weather Mats,Sunroof Visor,Fog Lights <-All OEM, Mugen Door Visors, 07 Tsx Wheels.
    1990 Accord Coupe CB7 (project)
    H22 Swap, Skunk2 Springs on Koni Str.t, Rear Disk Swap, Fog Lights, 92-93 Trunk Conversion, 02 Accord Rims
    look at your shifter cables under the center console.
    Yes my name is Dang, Don't use in vain
    1992 Honda Accord EX (Coupe/Bordeaux/Auto)
    1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
    2008 Honda Accord EXL (Coupe/SanMarino/6spd)
      they look attached wheres the one by the tranny? cause i took off the console it was connected...
        any one?!?
          the one by the transmission is on top of the transmission.
            i see lol well i'll take a look @ it when im outta work it happened lastnight couldnt see much..
              yes when you look at the tranny on the left side of the motor you can see the cables right on top of it and it travels back through under the car into the cabin to your shifter. good luck
                u trying pumping the clutch? might not be disengaged, and means u would have to replace the master cylinder. all i can think of right now.
                Turbo Setup: 100%
                  the rod that holds the shifts fork might be bent, take the top cover of the tranny off (where the vent tube is) and check the rod
                  Just do what PR CB7 said.
                    got it guys thanks it was the one on top of the tranny guess the pin got lost i just put it bk in ima have to buy a pin 2mo should i bother driving it like tht? cause i need to get to work some how & for after work i can stop by an auto store & get one..
                      good you found the problem.
                      but have fun driving in first gear the whole way there.....ask someone to take you to work.
                        He can slip the cable back on and drive... but I wouldn't recommend it.
                        Get a paperclip or something to hold it in place TO GET YOU TO THE STORE TO BUY A COTTER PIN. (I emphasize that last bit... because I could see many people on this site being lazy enough to just leave the paper clip in there as a cotter pin... and while it would work, it'd fail eventually)
                          that same thing happen to me right before honda day..i just pushed it back on and i raced my car like that..lol still driving it like that..and i got lucky..but i would not recommend it
                          Facebook - NYC ALIVE
                          -NYC ALIVE (Prez)-
                          -Accord Nation - Coming soon
