So,my ground controls seem to be stuck at the height adjustment that they're at.They still have more then half of the threads left to go down,but they just wont budge.Does anyone have any little tips or tricks to make them break loose?
Gc coilover sleeves stuck,help?
No,they look like the adjust has never even been down that far.Originally posted by JoshM View PostAre the lower threads damaged?
Also for the rears,the adjust is hitting the cup of the struts.Can't i just pop the adjuster out of the cup,adjust them lower,and just sit the adjuster back in the cup?
try calling up GC and see if they have replacement sleeves. I wouldn't mess w/ those threads if they're already effed up. If those fail, then your shock will slam down. So I wouldn't risk it if I were in that situation.
yes indeed it is. take it to a junk yard and if your careful, no scraped or bruised knuckles. lol.Originally posted by deevergote View PostPB Blaster is amazing stuff.
but do you have the wrenches that goes with the sleeves? normally if those 2 adjusters are put together tightly, your not gonna be able to turn them by hand.
Yup! This is what I can was going to say.Originally posted by OldMan'92Accord View Posthave you tried to loosen up the set screw for the height adjuster?? there is a allen head set screw in the height adjuster that needs to be loosened before the adjuster ring can be turned.
If not there is a GC "wrench" that you can use to adjust. Personally I'd put a rag over a screw drive and wiggle the screw driver into one of the grooves and try to tap it loose.
Make sure that the perch is loosened as mentioned above though!
or hit the nut with a hammer and a piece of aluminium
