Drop and clean the tank out. I just bought a CB that sat for 2 1/2 years and had a half a tank. Driving it around the shop it was doing the same thing you said. So today I went and got some Marvel Mystery Oil and 3 gallons of 100 octane. Put it in, drove around shaking the car to mix the gas up . It started doing it real bad, threw the 43 code. Restarted and held RPMs at 2500 for about 60 seconds and it just smoothed out. Did it just so I can still move it. Im going to run it out then clean out tank then change the fuel filter.
unknown ecu code
http://WWW.DUBWISE.NET
My Job!
9DUBWISE 92 LXhttp://www.cb7tuner.com/vbb/showthread.php?t=142580
RHD ITR conversionhttp://www.cb7tuner.com/vbb/showthread.php?t=172577
bad thing is was when i put the engine back in it got started with no fuel so it picked up all the junk at the bottom of the tank when mine statrs to idle rough i hold rpms at about 1200 then drive ill shut it off after it throws code and restart and problem goes away could have some water in it too i guess>> thanx i think ill drop it and clean it out!!
