my 1993 se dont turn on...HELp PLEASE
    hey guys im having problems with my accord right now .....i went to the store and wen i came out i try to started and the car would crank but not start....i try it soo many times till the battery died on me....know it been 2 days park soo i decided to go see if it starts, soo lucky me it did...soo im just wondering what could be the problem... it has to sit for a while in order to start up again...
    is it hot where you are? because it could be the main relay that's on the fritz.
      yea right now its really hot here in cali....thats what i was thinking too the main relay....could i fix it or i need a new one
        sure you can.
        http://techauto.awardspace.com/mainrelay.html
        most people will recommend that you solder yours instead of running out and buying a new one.
          You have to be patient and steady to solder it, but you CAN fix it. You could always take your chances with a junkyard one as well.
          The igniter and coil are also common no-start items that go bad in the heat.
            try to fix it yourself with the link above , if anything you can always buy a new one , learn as you go.
              finally got it fix it was the main relay wen out to the junk yard and got one ....now its runnin like new
              thanks alot guys!
                took you 5 months to fix it? damn. later.
                Avoiding dirt at all costs
                  jajaja naw it was working since that last day i had the problem but then it happen like 3 days ago again soo i change it and its starts good....i just post it up soo if any user read tru the tread they could get an idea u know
