The clicking sound during idle just started about 3 weeks ago on my stock 91 LX with 116k miles has been maintanenced since 91 but timing belts never changed
How long until my timing belt becomes a serious problem?
Originally posted by Potatoswatter View PostI've been told by garage mechanics that my car can survive a timing belt failure. (They were speaking offhand from memory.) This is untrue. Your car will be totalled if it goes. If you want more info, ask the garages what happens when it snaps as you call around for quotes.
A friend of mine had a 95 accord and it snaped while going 80 mph and that engine was shot.
im guessing going higer speeds the chances higer to dead zone
Links to my rides :
1992 Accord EX*
1990 Accord EX
1991 Accord SE (4th)
1991 Accord SE (3rd)
1991 Accord SE (2ND)
1991 Accord SE
I just bought a nice 93ex from a lady that had her timing belt snap for 100.00. it took me a while and some time reading here and great help from the members here. After a new timing belt water pump 2 exhaust valves balancer belt some shiny paint and a lot of time I got her running again. i would say it took me close to a month to get it done but it wanst working on it every day and all the time.
My recomindations is replace your timing belt balancer belt all the seals as well as your water pump your right there and it only takes a min to swap out. that way you know its good and one less thing to have on the back of your mind. Just look up the DIY and there is a video that i followed when i did mine. yes i tried to just replace the timing belt and found other bad things.
Good luck and dont gamble its really not worth it. unless you have to have a good excuse to get under your hood to put a port and polish on lol yes i did that too.
you are correct as they are 100% wrong. Sure the engine will survive...you'll just need new valves, new pistons, possibly a new head, etc etc____
Never chance it! Keep up with PMs. Its called an interference motor because when the timing between valves and pistons go out they interfere with each other. In other words----- SCATTER. Bad day!!http://WWW.DUBWISE.NET
My Job!
9DUBWISE 92 LXhttp://www.cb7tuner.com/vbb/showthread.php?t=142580
RHD ITR conversionhttp://www.cb7tuner.com/vbb/showthread.php?t=172577
