ECU chipping questions.
    I've read the sticky in the Tech section, but i can't post over there yet. It says any ecu can be chipped to any ecu equivalent. So, I found a p72 locally for $10 out of a '99 GS-R... Want to double check chipping this for my 93 Accord. Now it's stock, but a turbo kit will be coming in a few months.
    Also, is there any benefit from the VTEC ecu when going in a non-VTEC application? Do I need to remove the VTEC components from the ecu or just leave them?
    That ECU is OBD2, and is of no use to you. You need an OBD1 ECU (1995 or older).
      IF the ecu were OBD1, vtec is of no use to you. You would simply disable it in the program. You wouldn't need to remove any components from the ecu.
        Well damn.. Guess I'll keep looking.
        Thanks
          What I would do is either go through reputable companies like phearable.net or xenocron.com and either just buy a chipped ecu outright or just go to the junkyard, find an OBD1 honda ecu for cheapo and ship it off. Should run you no more than $150 and turnaround is usually about a week.
          '94 JDM H22A: 178whp 146wtq
