swapping f22a4 im my car cause i blew my engine(i have the f22a6) only problem is i dont know if it will work because of the f22a4 is an auto and mine is a 5 speed and all i want to do is use the a4 engine and my trans. I know intake is a different setup and it has a different ecu and shit like that all i really want to know is if its possible to swap the engine into mine and keep the 5 speed trans without major modifacation
f22a4 engine swap
from what i've learned from this site, yes you can keep your 5speed without major modification, they are interchangable, but i'm not so sure about the ecu.Originally posted by sg4life92 View Postswapping f22a4 im my car cause i blew my engine(i have the f22a6) only problem is i dont know if it will work because of the f22a4 is an auto and mine is a 5 speed and all i want to do is use the a4 engine and my trans. I know intake is a different setup and it has a different ecu and shit like that all i really want to know is if its possible to swap the engine into mine and keep the 5 speed trans without major modifacation
i'm auto and planning on going 5 speed,
good luck
