My heater wont work !
    My heater is currently not working . Before it stopped working , i would have to hit under the dash on the passenger side in order for it to work. What could be the problem?
    When i was changing out the ecu , like 2 days ago , i saw a plug and it was unplugged and i couldn't see where it could go..
    if the plug was blue or maybe brown with two prong connector dont worry. that is the jumper to check the "check engine light".
    your heater core might be clogged causing you to not have heat. trying getting it flushed.
      wat u mean flush take it to someone or is there like stuff i can buy at my nearest auto part store???
        Is it blowing any air at all?
        -Will
          no its not turnin on at all
            look under the dash on the passenger side between the heater/ cooling blower motor and the kick panel. there should be 3 connectors there.. a big one and 2 small ones. the middle plug is for the blower motor. its a 2 wire, blue/red and yellow/black..make sure its plugged in and not loose.
              thank you sir i will check that out 2morrow nd does it mtter if i hve a dx all the same wiring?
                i think the blower motors are the same, so it wouldnt matter
                  or maybe the heater fuse or relay went out
                  view my ride: My Ride
                    yeah, possible..its just kinda hard to say..
                    he did say that he saw a loose connector...
                    but then again, he also stated that when he hit the underdash it on come on..so possible...
                    could also be a bad blower motor acting up...
                      Nope your blower motor is blown same shit happened to me.
                      -Will
                        yeah it was my blower motor took me about an hour to chage it thanks guys
                          cool..glad to hear, problem solved
                            check your fuses and relays
                              I have to hit mine sometimes to get it to work too lol.
