Turbo building "?", engine and trans
    well like the title says, i have some "?" about these engine. my plans are to get used F22A6 and build it from the inside out. i never built a motor for boost, but i do know my way around engines. obviously ill do new rods and low compression pistons, but will stock crank bearings hold up? do i need to do anything to the crank? and put a cam in it, ideally i would like to run 10-14PSI of boost if possible and keep the stock trans and basically as stock as i can, i dont want 300+ hp, but if thats what it will put out, and be reliable, sure i read about the injectors too, but will the stock fuel pump put out enough? and lastly the ECU, how do i go about tuning or what
    did you check the Forced Induction section under Technical/Performance?
      If you're only looking for 10lbs, you could get away with a stock F22A6. It'll give out eventually, but if it's healthy, and you don't beat on it, it'll last for quite some time.
      You will need new injectors for sure. DSM 450cc injectors work well enough for a low boost setup.
      Your transmission will hold up just fine if it's healthy. Assuming you have a manual transmission, you're going to want to get a stronger clutch to handle the increased torque. Spend the money on a decent one. I bought an XTD "Stage 3" clutch, and I really regret it... it looked nice, but it blew up with nothing but a moderately-driven stock-ish H22 putting power through it.
        yea planned on the clutch up grade. now it is burning oil so i maybe resealing the whole motor, and all new rings and bearings. so it may put my turbo spare motor on hold. but if i can do a low boost on stock internals being they will be brand new it should hold out for some time? will the stock honda rings and bearings hold up or should i look into aftermarket?
          People have boosted completely stock, original internal motors to 10psi with no problem. As long as the motor is healthy, and the tune is good, it should last for a while.
            it's all int he tune.
              and the original health of the motor. And the size of the turbo.
              But mostly the tune.
