i want to put on a short ram but i want to first know how to remove the stock one first.....
how to remove stock intake?
unscre the 4 bolts that hold on to your obx air box, after, femove the one screw circle thing that holds the box and intake pipe. then just remove it and install the short ram intake.
Dude
If ya got the INT. an ya have the tools, take a leap i mean its just the INT. but im a big motor head an luv to do late night proj.'s n Sh*t,
I always like bein better safe then sorry but. This project your trying to do is fairly easy and quick too accomplish...to get those heads turning to check out your ride
Be safe and i guess do sum more searching to get this one right GLI want to die in my sleep like my grandfather... Not screaming and yelling like the passengers in his car
My Ride
*****;http://viewmorepics.myspace.com/inde...lbumId=2844229*****
Oja Thnx Everyone, at cb7tuner.com
There is also a lower resonator part of the intake that you forgot to mention. I forget exactly how to take it out but it is really easy. As you do it you can figure it out.Originally posted by pedroalcala View Postunscre the 4 bolts that hold on to your obx air box, after, femove the one screw circle thing that holds the box and intake pipe. then just remove it and install the short ram intake.
