f20b non vtec?
    But there is a dohc f20 non vtec right .. Cant seem to get any right info on this engine
      that would be the F20a DOHC, 150PS, 180++ Nm. came in the CB3/4 Si
      Click sig to view MR thread
      Links to other rides:
      Honda Accord Euro-R
      Honda Odyssey Absolute
      Honda City I-DSi
      Honda Stream
        Correct. There is no F20B DOHC non-VTEC. If someone is trying to sell that to you, I've got a really nice bridge that would look great with your name on it as well!
        If you want cheap, reliable, and upgradable, just go with an H22. They're fairly inexpensive now, and parts are common. When you buy some Japanese engine that we didn't have in the US, there's a chance of a part breaking that you won't easily be able to find. MOST parts are interchangeable with US parts, but I'm sure there are some weird ones.
          Thanks blizzard. Deevergote (Correct. There is no F20B DOHC non-VTEC. If someone is trying to sell that to you, I've got a really nice bridge that would look great with your name on it as well!)
          You said theres no f20b non vtec dohc that is wrong, yes there is . 1000 plus is not cheap for a h22. I really dont want a h22 but if i get the f20b non vtec I could put a vtec head on it right. How hard is it to wire the vtec, and if i put i vtec head on it its basically would be a f20b vtec , the one stock from japan
            There is NO such thing as a F20b DOHC non-VTEC. The non-VTEC versions of the F20B were only SOHC
            PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
            Listen or download the first 4 songs I completed for my new upcoming album here!!
            My member's ride
              well i am new to accord but someone gave me a spec of the f20 non vtec they said 197hp. if not what does it supposed to have, and no i dont want the h22 in my eyes the motor are junk i dont like those engine at all. In my experience on messing with them the are very tempermental engine.. Every little thing make them throw a fit.. Well anyways im not looking for much just want a car that will run between low 14s to high 14s and be a everyday driver, without turbo
              don't mean to argue but how is the h22 motor junk? i've heard ppl make this claim before but nobody can ever provide evidence for such a laudable claim. so i'm just curious as to why you say the motor's junk?
                ABSURBNY, Theres no f20b non vtec look at this http://jdmtigerjapanese.com/details.php?id=5577 Whats this then.
                Jdmwannabee, Its just from my experiece working on hondas, doing swaps and people bring there preludes to me to work on. They are very pecky and tempermantal engines. Every little thing makes them run like crap. Maybe its just the engines i came across
                  A F22B. They must have the description wrong because I have never heard of a F20B DOHC non-VTEC. Either that or someone popped a non-VTEC head on it.
                  Has anyone else ever heard of a F20B DOHC non-VTEC?
                  My member's ride
                    There is no such thing as a DOHC F20B non-VTEC motor.
                    cb715401, you seem like you think you know quite a bit.
                    The H22 is actually a very forgiving motor. It responds very well to mods, and can easily run low 14s with a quality intake, header, exhaust, and cams. I've known H22s to run low 14s with just I/H/E. Someone who treats their motors like crap, or buys them from a questionable source, will very likely have a poorly running motor. I got my H22 from a reliable source, and I've maintained it. I have had no problems that haven't been due to normal wear items failing.
                    There are NO non-VTEC Honda 4 cylinder motors that make anywhere near 200hp from the factory. The most powerful non-VTEC motors are the H23 and F22B DOHC, both at 160hp (the H23 has more torque due to the greater displacement.)
                      Well I to like think i know alittle bit, but when it comes to accords and preludes im in the dark as far as the motors there are. Thats one reason i join this forum. Most of you guys know more then me when it comes to these motors. OK so ii shouldnt get this engine ,ok,
                      Is the h22 swap pretty much like putting a gsr in a ls integra
                      If I deside to boost would the f22 be good canidate.
                      IF I deside to keep the f22 and go na whats the best modes besides the h23 im.
                      I would like to get around 180 to 200hp and right now i only have about 800 to spend
                        The F22A can make insane power NA, but you need to put some real money into it. The Bisimoto header alone will give you 27whp on a stock motor (stock intake and exhaust, even).
                        For $800, if you understand turbo systems, you can build your own setup for that. It won't be great, but it's doable. You're going to need to be able to tune the ECU, or find someone to do it for you, though. The F22A can make 200whp EASILY with even a cheap turbo setup. The compression is low, so it's fairly forgiving.
                        The H22 is nearly a direct swap into the CB7. You have to run 4 wires and tap one hole in the manual transmission. Otherwise, everything goes right in like stock. There are members here that can do the entire swap in a matter of hours.
                          deevergote thanks for the quick reply and great info. Yeah as far as turbo that might be the way im going to go. I have a custom that i put a new stock turbo on his 89 mx6 gt. And he didnt pay for it so its mine.
                          Has anyone did a hybrid turbo setup from a mx6
                            You are probably better off selling that turbo you have and then getting a DSM setup. It is the easiest and cheapest way to go turbo on a our motors. .
                            My member's ride
                              Dsm setup so the manifold would bolt up?
                              Should i just by everything that has to do with the turbo ,hoses , bov , wastegate , sidemount intercooler, oil line, everything?
                              What would i have to buy besides that , how much moding would it consist of
                                How big is the turbo from the MX6? What type is it?
                                The manifold on the 4G63 (DSM... Eclipse, Talon, Laser) matches the F22A exhaust ports, so all you need to do is drill new holes to mount it. It's a very common thing to do when boosting on a budget. It will fit the stock Mitsubishi 14b (which works, but is small for the F22A), as well as the 16G and "big" 16G from the Evo3 (that's the one you want.)
