Battery light on.. bad alternator?
    As am driving, the damn battery light comes on
    pulled over to see if the belt had snapped or anything but it was still moving in rotation..
    i turned the car off and turned it back on and the alternator belt continued to rotate but the battery light is still on..
    could it be a bad alternator?
    are yu running any type of sound system? and did you check if the belt is tight because if its loose then it will flicker on and off,
    lovin every minute of it
      yes
      Yes my name is Dang, Don't use in vain
      1992 Honda Accord EX (Coupe/Bordeaux/Auto)
      1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
      2008 Honda Accord EXL (Coupe/SanMarino/6spd)
        yea i do have a system
        not flickering, just solid
          how old is your battery? and it sounds to be a bad alternator, but before going out and spending money check the belt tension and if your batteries still good
            duralast gold, about 6 months old
              hmm well i know some auto parts stores test batteries and alternators for not that much or you can try this, an old way my dad used to do is to turn the car on and take the negative wires off the battery if the vehicle keeps running, the battery could be bad. If the vehicle dies, the alternator is probably bad.
                He is right. This is how i diagnosed my alternator to be bad.
                -Lance- (Formally known as H0ndaspyd3rLM)
                Originally posted by H22Artman
                if he still disagrees. well...... buy him a pink sweater and tell him to go buy some curtains.
                I posted a nude photo of myself on cd5tuner.com... it broke the site.
                Bought from: lo_dit, 924dr, Fatman88, 91project, noobcake, loud92cb7
                ٩(•̮̮̃•̃)۶
                  Yeup Your Alternator Died Did you wash your engine bay? thats how i killed my alternator lol the battery light kept flickering till sudden my engine ate all my battery and my car died then waited for and hour and it started again got home did the old fashion way taking out the negative on the battery while running "dont worry it wont shock you" then car shut off then alternator died =] got it rebuild for 70$ then good has new.
